Hi,
I'm trying to avoid buying another tv and vcr for my office room and wondered if it were possible to use my big, new computer screen instead? In the past I have had my tv/vcr and sky digital system connected to a second television in another room via a single cable from the vcr, and wondered if the same set-up is possible with a computer?
I've got a very new, powerful computer with a big, Samsung, LCD screen. In my ideal world I'd like to be able to connect the VCR to the computer and therefore be able to also watch Sky satellite and normal tv on the video channel through the computer screen.
Do you know if that's possible.
Many thanks in advance.
A TV tuner card might help!
They come pretty cheap these days, if you don't care for hardware encoding and fancy stuff...
/Mats -
Thanks a lot. Do you just whack it in the back of the computer then? Is there usually a dedicated slot for it?
Hmmmm! You're obviously not a very experienced computer user so it may be better for you to take a look at the external TV tuners that plug in via a USB connection. It will save you having to open up the 'pooter to plug in a card.
However if you do feel brave a TV card plugs into almost any slot inside the PC. In fact the shape of the card will make it fairly obvious where it goes as there will only be one set of sockets that will accept it.
If you have any aspirations towards capturing TV progs and generating DVD's or VCD/SVCD's then it may be worth doing a little investigating by clicking on "Capture Cards" to the left of this message.Artificial intelligence is no match for natural stupidity. -
Thanks, and you're right, I'm not overly knowledgable!
If I go for the USB jobby, does that enable me to connect to my actual video recorder, or would I just be tuning the computer into a tv arial? -
connecting the vcr should be the same as the tv signal, though u may not be able to do both at once, looping tv through the video may let you do this
Right, thanks, so if I understand this correctly, I should be able to buy a USB tv tuner, connect one cable to it from my video recorder (which is already connected to my Sky digital receiver and television arial) and I'll be able to see my video tapes, sky tv and terrestrial tv through my computer?
What USB tv tuner would you advise, and what's the difference (apart from the connection) to one that you would install internally? -
What USB tv tuner would you advise, and what's the difference (apart from the connection) to one that you would install internally?Artificial intelligence is no match for natural stupidity.
How to watch HD .mov files on computer
By kaisaka in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2011, 13:10 -
need to watch verizon fios tv on my computer
By greendesert in forum DVB / IPTVReplies: 0Last Post: 27th Jul 2010, 10:08 -
svhd to watch on my computer
By poolboy314 in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2010, 15:00 -
Can I watch a PAL dvd on my computer?
By dredle1 in forum ComputerReplies: 7Last Post: 9th Oct 2008, 23:18 -
watch dvd movies on computer
By jfmalone in forum Software PlayingReplies: 10Last Post: 13th Feb 2008, 17:30
