I accidentally update to the new official 1.10 but would like to use the patch but tried to and it failed. Advise ?
More information please ......
I updated the Firmware of the Pioneer 107D to the official 1.10 but after hearing I can use the older Riteks G04 to 8X I would like to flash it to the hacked 1.10 but tried it and failed to flash. Advise ?
Hey Bud :
Use the files provided by Flashman to flash your drive to the patched 1.10 software. However bear in mind you won't be able to burn at 4x anymore. its 2x, 6x and 8x with the patched firmware. You can get the files at http://flashman.rpc1.org/Firmware/PIONEER/DVR-107D/Patched/
If you get the WindowsXP zip archive, it includes a shortcut file called Flasher that you can Right-Click and select Properties and in the Flasher Properties Window, click on the Program Tab and change the Cmd Line: Box to reflect the correct drive letter of your Pioneer 107D drive you are ready to flash.
Hope this helps you ....
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 03:45 -
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 14:25 -
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 21:03 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 06:50 -
DVDR-3380 Firmware upgrade
By Spideray in forum DVD RippingReplies: 2Last Post: 25th Jan 2009, 02:13
