i have a strange problem .
i downloade 2 movies last day and both of them are flickering.
its strange because them both downloaded from different source and the both acting the same.
i tried to watch them with media player and also with powerdvd and same thing with them both. the movies are from avi type, regarding to other avi movies i already have on my h.d there is no problem.
what could it be ? i think the problem is in my system but i dont know where also i dont think its have anything to do to the codec or maybe im wrong.
p.s
two days ago i installed cce and avi2svcd and unistalled them i unistalled avisync with them, maybe i uninstalled something that effect on avi's ? but then again as i said there is no problem with my old avi's files.
please help...
ok i installed gspot but im not realy sure what result to wrtie here so here it goes :
the codec is xvid and its also write that 2 compatible codecs installed :
Xvid Mpeg-4 codec & Xvid Mpeg-4 video decoder.
this is at the video .
at the audio :
Pcm audio
and at stat : No codec required
at the second avi files same thing at the video and at the audio :
0x0055(MP#)ID'd as MPEG-1 Layer 3
stat : 2 compatibe codec installed --> Fraunhofer IISMPEG Layer-3 Codec (professional) and MPEG Layer-3 Decoder.
thats it ? -
Hi,
The avi's are most likely encoded with the new version of the Xvid codec.
I used to play all Xvid/Divx with FFDshow filter, but got the same "flickering" effect with a couple of recent avi's (in PowerDVD too).
What worked for me was to install the new Xvid codec and play the avi's with the Xvidcodec instead of FFDshow.
The new version of FFDshow (mentioned in the tools section) will play the "new" Xvids without the flickering (tested on another pc).
New Xvid codec : http://www.roeder.goe.net/~koepi/xvid.shtml
Hope this helps
Regards,
Hitrec -
hitrec - it worked thanx !!! hoooo i thought im facing infront of big problem here , guess not, THANX .
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Strange audio sync problem with downloaded AVI
By embreeb in forum AudioReplies: 9Last Post: 9th Dec 2008, 09:30 -
Strange AVI Problem
By HacktheHacker in forum DVD RippingReplies: 3Last Post: 14th Apr 2008, 11:44 -
Strange avi files
By rubnz in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2007, 17:17 -
Strange problem converting Xvid AVI to MPG2
By joelore in forum Video ConversionReplies: 18Last Post: 2nd Jun 2007, 00:40
