Suddenly my Ritek GO4 DVD-R discs will not Burn anymore. I keep getting failures. The discs show up as DVD-R with the correct capacity but fail after the lead-in is written. Im about half way through a 2 month old 50pack of Riteks that worked perfectly until today when I made 3 coasters in a rowIs it my drive? Nero? or the DVD-R discs? Is there anyway to test with out sacrificing another DVD-R disc?
DVD+RW and CDR Burn fine!!! I burned the same project on a DVD+RW without issue.
DVD Decryptor 3.20
DVD Shrink 3.1.5
Nero Express 5.5..
NEC ND-1300 fw1.07
Results 1 to 15 of 15
Hi Machineman,
If you have 2 or 3 failed in a row, then stop burning, reboot your system and retry it. It will refresh your system. If it still fail againn, it may be the media.
Because the software you use it daily already, make sure you did not update software, if you just up date and it have like that then you know what to do, BTW did you update DVD Shrik to 3.17 beta, or using 3.16 ? I heard 3.16 have some problem.
Let me know what you found out.
Cheers, -
You could also try uninstalling/reinstalling your IDE controllers, and upgrading the firmware. No guarantee that this will fix it, but it won't hurt to try.
not to be funny--try another brand of media. I had the same problem with Ridata/Ritek printalbe G04s--I switched to a tdk branded G04 and it worked fine.
Update:
I installed DVD shrink 3.1.7 beta5 along with a reboot and it works now.
Not sure if it was the reboot or the DVD shrink but I suspect rebooting solved the problem and the issue was with the Nero burning engine. -
Before you start tearing your already proven software/hardware apart, I suggest you go to nearest office supply store and buy a 5 pack of jewel case media (TDK, Fuji).
I haven't found any bulk Ritek G04's that work for me.
I'm using same burner/firmware as you (and a liteon 451s too). -
i highly doubt its the media with a fail after the lead-in.
more than likely a hardware or software fault -
MeTaL, you dare question my authoritay.
I weren't thinking rightly.... although I have trouble with Riteks, they burn/play well in my recorders. Most Riteks I've tested were thin on the outside (leadout)...the inner usually is solid (low PI/PO). I still wouldn't touch your software if it worked well previously. I would check that the drive is in DMA mode and defrag my harddrive(s) first. If that doesn't work...then eliminate media as the possible culprit. -
Update:
RG -
Originally Posted by RAAGAAman
either way, hurts compatibility for my older players.
Sorry, MM, didn't mean to beat this one to death...missed your "fixed it" post. -
Maybe I missed it but I don't think anyone mentioned running a READ ERROR test after the burn is done.
This can be done with DVDInfoPro available as adware freeware or adfree payware.
You could burn a DVD disc and think all is well but actually it could be riddled with read errors so doing that test is key!
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Problem Burning RW Media on SH202J
By builder in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th May 2008, 10:38 -
What is your favorite burning media for video?
By yoda313 in forum PollsReplies: 29Last Post: 12th Apr 2008, 16:59 -
*SOLVED* Media problem or workflow problem? (Media problem)
By nosleep in forum Authoring (DVD)Replies: 7Last Post: 2nd Jan 2008, 20:35
