I have some mpeg streams that look like they were deinterlaced. the video that was deinterlaced was telecined video. i would normally run an inverse telecine (ivtc) filter on the video and then encode it, however there is nothing left for the filter to find and the video will not ivtc correctly.
here is what the pattern looks like in virtualdub when i have telecined video
29.97
1. frame
2. frame
3. frame
4. field
5. field
however in this case it looks like this:
29.97fps
1. frame
2. frame
3. frame
4. mixed
5. mixed
what i want is the usual normal so called problem:
29.97fps
1. frame
2. frame
3. frame
4. frame
5. frame (duplicate of 4th frame)
normally my IVTC filter looks at the fifth image and removes it because it's a duplicate of the forth. well now that it's mixed, which i'm guessing is the deinterlaced blend thing done to it, i can not seem to convert my video from 29.97fps back to 23.976.
is there anykind of plugin or method in tmpegenc or virtualdub that i can use to convert the video back to regular so that i can run the ivtc filter as usual?
Or are there any suggestions to my perception of the problem?
Kreg
Results 1 to 1 of 1
undo date modified on "favorites" files
By gordes04 in forum ComputerReplies: 11Last Post: 21st Aug 2011, 17:07 -
Can anything undo disproportional "stretch-o-vision"?
By tluxon in forum Video ConversionReplies: 10Last Post: 2nd Jun 2010, 04:43 -
Sony Vegas: Any way to undo clip speed adjustment?
By duderdude2 in forum EditingReplies: 2Last Post: 15th Feb 2010, 21:03 -
To deinterlace or not deinterlace...
By Nilfennasion in forum MacReplies: 4Last Post: 4th Dec 2008, 00:46 -
Do I need to deinterlace? Or never deinterlace?
By rbatty11 in forum Video ConversionReplies: 12Last Post: 17th Jan 2008, 13:15
