Hi all, I've got a problem. I have a movie that is split over 2 DVD's and I'm trying to downsize it so that it'll fit onto one disc. I'm trying to do it with DVD2oneX, version 1.3.0 but I'm having no joy at all. The DVD's are 4.2 and 3.9 GB's respectfully but I don't think that's relevant. I'm trying to do it using DVD2oneX (as I said) but I'm getting errors. I want to downsize both parts to 2.2 or 2.15 GB but DVD2oneX is giving me errors. I've used this function of DVD2oneX before (to backup my copy of Goodfellas (2 sided)) and it's worked like a dream. I'm getting 2 dialog boxes that say 'For full diskcopy you need to copy all files from the DVD in file mode.' and 'Unable to allocate memory for file buffer.' I've also tried using the demo version of DVDRemaster v1.3.0 and it doesn't want to know either. Anybody have any ideas? I'd appreciate it so much.![]()
Results 1 to 11 of 11
this movie thats been split? where did it come from.
it sounds like dvd2one is thinking its not a complete dvd since its been split? thats my best guess
are you just wanting movie only? if so you can just pull the movie files and compile them with something like Sizzle and then have it build you a new complete VIDEO_TS fodler which can then be crunched through dvd2one to resize its output.
the only way the JOIN feature isnt working is if they VIDEO_TS of each dvd you are joining is not complete [ie a whole dvd] which is often the case with split dvds! -
Try a forum search for exact instructions, but I think it involves using DVD2OneX on each disc first, setting the size to about 2.15 GB in film mode. Then, once you have both halves of the movie shrunk down, you use the join function, and add all the cells from the 2nd half to those of the first half.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I have had success doing 2 seperate movies each full dvd9s where it JOINS the movie only's into one single dvd5 no problems
I think however if you "aquire" a split dvd where it has working menu for both disks, but only 1/2 of the files of the origional dvd dvd2one botches up
is this dvd in question one of those? -
but why on earth would u want to put 2 movies on one 4.3 gig dvd.. i mean especially if either dvd is over 4.3 gigs already.. the quality would be TERRIBLE (edit.. sorry didnt fully read original post didnt realize it was a movie split to two dvds.. the quality will still probably suck pretty bad)
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
actually you would be surprised!
i remember backing up pearl harbor way back when... it was 2 dvd's that I compressed to one dvd [ manually mind you, the join feature was not out then]
the quality comparison to any dvd9-5 is strickingly high
mind you its not perfect
but its well beyond SVCD range
Sorry that I didn't reply for a while to this but I've been up to some other things. I tried all kinds of methods with this problematic movie (including trying to feed the .VOB files to Sizzle (it spat them out), using VPC and IfoEdit to create new .IFO & .BUP files (no good)) and have eventually trashed the source.
Yes, DVD Player would play them OK and select chapters but the source has been binned anyway now so it doesn't matter anymore. Thanks anyway.
downsizing a mov on mac
By devdev in forum MacReplies: 1Last Post: 18th Apr 2012, 11:13 -
Downsizing from 1280x720 while maintaining 16:9 ratio
By pooksahib in forum Video ConversionReplies: 13Last Post: 22nd Dec 2010, 15:18 -
Resolution downsizing
By neroguy in forum Video ConversionReplies: 7Last Post: 17th Jul 2009, 22:58 -
The unmitigated ruler of downsizing algorithms?
By The.Yield in forum Video ConversionReplies: 5Last Post: 9th Nov 2007, 19:02 -
Guide for downsizing xvid files?
By bogart219 in forum Newbie / General discussionsReplies: 5Last Post: 11th Oct 2007, 06:35
