  1. Help Help Help !!!!!!
    I am new to this, I am currently recording off digital channels using a TV capture card. I am capturing in MPG format 768 x 576.
    I encode the file in TMPGenc, loading "SuperVideoCD (PAL)" creating a new MPG to burn onto CD accept the sound on the file is out slightly.
    I then load the file through DVD2AVI, save project to split the file in to the files "Filename.mpa" and "Filename.d2v".
    Only the d2v file is created the mpa file is missing !!!! ????
    Can anyone help ?
    K
  2. Try splitting the file with TMPGEnc tools (on the file menu). Use either demultiplex tool there.
  3. I will try and let you know.
    Thanks for your reply
    (Have been scratching my head for far too long)
  4. It goes like that. There's no quick and easy, one method always works here.
    My biggest problem was the codecs.
    Beware of installing / uninstalling anything related to audio/video!
    I suspect some programs goof up codecs even when you just run them, but not competely sure yet....
