  1. ok, I copied a DVD5 movie to my HD with dvd decrypter. I burned the VIDEO_TS folder with nero on udf 1.02.
    I get the initial screen (the movie that plays before the menu shows up), but nothing after that. this isn't the first time it's happened. what's wrong? how do I fix it?
    it works on the computer but not on my dvd player.
  2. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    If it's a DVD5...
    use Decrypter > mode > ISO > read
    then use Decrytper > mode > ISO > write
    If it works on computer but not player that is usually a disc compatibility issue or disc quality issue....buy better media, your stand alone doesn't like the one you are using.
    Jul 2003
    Yeah, if you just burned the VIDEO_TS folder, then something got goofed up somewhere. Like North said, just hit everything in one shot, and burn everything in one shot.
