This has probably been covered a million times, but hey..
I'm using Ulead VideoStudio 7. I keep my audio to 48Khz, when I play and look at my final clips that I make from a DV camcorder, everything is fine. Even up to the last preview, everything is in sync....
BUT
When it's burned onto a DVD, the sound ALWAYS leads the picture by about 2 seconds. Why is this? I have tried everything. It's costing me afortune in DVD's. Surely there must be a simple tick box I can check?
Any help? Please????
Starting today inis forum, I noticed sync problem to be the most reported ones. I just posted somewhere else the below:
One of the reasons audio and video is out of sync is caused by the DVD player not being fast enough to handle the bitrate.
This specially happens when you create your own video (not just copying a DVD movie to another DVD), and (re-)mpeg it. As you probably want to get the highest quality possible, the codec will generate a file with a very high bitrate. Many (stand alone) DVD players simply cannot handle these high bitrates.
At least that's what I found out after going completely crazy and blaming my software, my burner, my TV, etc! I always thought that it couldn't be my DVD player, as it would play copies of DVD movies (burned on the same media) without a problem.
So, try to find a setting to limit the bitrate.
Good luck!
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
