I use DVD MF2 and when I author the dvd, I have two titles and multiple chapters ( i added chapters in them automatically) in them.
How do I create or edit the image so that I can just have one title and multiple chapters in the title?
I tried searching but am not very familiar with ifo edit & vob edit.
I've tried merging the mpegs but the software that I use (easy video joiner & avi mpeg joiner) doesn't do a good job of combining the mpeg.
thanks.
You should be able to add the two MPEG files on the same track - you can definitely do it in TMPGEnc DVD Author. It assumes that the start of the 2nd MPEG is just another chapter point in addition to your custom points.
If in doubt, Google it. -
yup it worked but when I watched it, there were some frames that were bad (where the two clips connected).
However when I watched it with two separate titles in Ulead DVD MF2, it looked a lot better.
anything I need to do to make it better?
thanks.
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
best 3d title
By me_achu123 in forum SubtitleReplies: 0Last Post: 16th Sep 2010, 12:06 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16
