I'm trying to convert my DIVX avi into an MPEG movie using the guide that is on this site but I keep gettin an error message every time I try to extract the audio into WAV format before using it in TMPGEnc.
This is what the message says "No audio decompressor could be found to decompress the source audio format". But, the movie plays fine in windows media player both video and audio play properly.
I also checked the audio compression located in the audio stream section of file information and it says "Unknown (tag 2000)".
What shall I do to get VirtualDub to extract the audio correctly?
I clicked on those links and downloaded and installed AC3-ACM Decompressor for VirtualDub. And it worked. Thnx for the help.
Virtualdub and audio codec missing.
By nzdreamer55 in forum EditingReplies: 20Last Post: 30th Dec 2013, 00:32 -
No codec available when audio loaded in VirtualDUB
By Bucic in forum AudioReplies: 4Last Post: 27th Nov 2010, 18:13 -
VirtualDub: "The audio codec cannot compress the source to the desired
By user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 20:35 -
Samsung SVI Audio codec not recognised in VirtualDub
By gjdgjd in forum AudioReplies: 2Last Post: 1st Jun 2008, 08:39 -
Virtualdub jammed audio codec
By paros in forum EditingReplies: 6Last Post: 7th Sep 2007, 15:58
