When i go to create a batch encode i can't just add files into a batch encode list, it actually asks me to open a list. How do i actually create a list? :Tougue twister:
I remember on an older version what i had, youb could just add files and click go.
hello!!
OK, first set-up everything is TMPGEnc just like you would if you were to make just 1 movie. When you get to the part where you would normally hit the "Start" button, go to "File", drop down to "Add current project to batch list", pick your output type, and you are done. Keep going until you are ready to start the batch encode then got to "File", "Batch Encode", and a little window will pop-up with all the projects you want to encode in it.
Hit "Run" nad off you go.
Tom -
When i tried adding additional files to the current one that i added to the batch list it just said illegal streanm format like it does when it asks for a list
hello!! -
Try re-installing the software. Also check the HD to be sure there is enough space.
I beleive that tmpgenc is the only one that has the batch endode feature.
just make and save each project 1 at a time then open batch encode click ADD to add projects
If your getting illegal streanm sounds like source is iffy to start with
MainConcept MPEG Encoder can allegedly batch encode (don't work for me - as soon as I add 2nd project 1st one disapears from list!! )
Date Created - Batch Encode
By conandrum in forum Video ConversionReplies: 15Last Post: 14th Nov 2013, 16:57 -
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 08:10 -
Simple batch encode H.264
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2009, 13:32 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 21:52 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2007, 00:13
