I am new to this forum and it looks like many of you have a great knowledge in video. I just made my first conversion from D8 to DVD last night. I am using my Sony D8 to also input my 8mm tapes. I have about 45 more tapes to go. I also have some VHS tapes that I want to put to DVD and I want to know what is the best way to get it into my computer for the final process. I have an AMD 3000+, 512 RAM, and 160 GB HD and I am using Ulead Video Studio 7. I was looking at some video capturing devices online and they all have different capturing modes. I know that DVD is 720 x 480 but should I use that same resolution to capture VHS? I would like to buy the right equipment without breaking the wallet.
Steve
I'm guessing your DV cam doesn't have any sort of 'pass-through' function to it?
I have a Sony Digital 8 camera, and on the side are 3 RCA ports, as well as S-video and standard audio jacks. I output from the VCR to the camera, and then into the computer- the camera converts the signal to a DV stream for me, and that's how it's captured in the program I'm using (FCP).
Of course, you don't get a time code or the ability to control the VCR's controls through the computer, but it's a small price to pay...
The ATI AIW cards come with capture devices that allow you to import analog signals, and there's several video 'bridges', which basically have 3 RCA ports on one end and a FW cable on the other...
Slightly OT: Roxio announces VHS capture Device Solution
By terryj in forum MacReplies: 5Last Post: 30th Apr 2012, 23:19 -
Best VHS capture device
By underworldmagic in forum Capturing and VCRReplies: 27Last Post: 2nd Jan 2012, 05:09 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
What device to use for VHS capture ?
By dazz700 in forum Capturing and VCRReplies: 3Last Post: 17th Mar 2009, 15:18 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
