Hello,
I have been very successful creating svcd from avi's. I just got a dvd burner and now want to convert some of my avi's to dvd. I have read all the guides and searched th forums for the last 3 days and have gotten very confused on the audio issues. I open the file in gspot.
audio format
name = 0x0055(MP3) ID'd as MPEG-1 Layer 3 9 i knowthis is mp3)
status = codec is installed
biterate = 96 kb/s (48/ch x 2 ch) CBR Fs = 44100 Hz
video formate
codec
4cc = DX50/DIVX Name = DivX 5.0
status = code is installed
Aspect = 352 x 256 (1.375 : 1) bit = 791 kb/s
framerate = 25.000 FPS ( i know its pal my dvd plays it) duration = 01h 17m 56s
I know that there are audio sync problems if you don't convert the audio to wav. my question is do i need to still extract the audio since it is already mp3 since i'm now converting to dvd? When I did the svcd I use tmpgenc wizard to convert the video to the proper formate and add the audio i have extracted from goldwave as a wav. from what i have read over the last three days i understand that wav audio takes up alot of space and I would like to fit as much as i can on one dvd. Thanks in advance for any help you can give me.
audio spec (Pal or NTSC) from "what is DVDR":
Audio:
48000 Hz
32 - 1536 kbit/sec
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio
might look at AC3 or MPEG-1 layer 2 as less space-consuming options.Always check helpfiles/instructions before leaping...
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 20:13 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting .VRO file onto a DVD disc (to play on standard DVD players) ?
By superman123x in forum Video ConversionReplies: 21Last Post: 24th Mar 2008, 17:40 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
