Hi
I burned my first svcd with toast 6. In the edit/video dailog, I clicked for chapters every 2 minutes. The Cd burned OK, playable, etc. with a menu, however, when I go to do the chapter adavance, it takes me back to the main CD menu.
I remember this being an issue with MMT, does anyone know if chapters work with Toast 6 SVCD's?
thanks
Your settop player has to support PBC for SVCD. If it doesn't, your disc will play track by track, and may return to the menu if it supports displaying the menu.
most players have a PBC button on thier controller. Check yours and make sure its in teh proper posistion (on / off) then give her a go
they work for me when i do dvd with chapters in toast -
Toast doesn't support Chapters for VCD or SVCD, only DVD. You will notice that the title of the pop-up in toast says "DVD Chapters".
man i should not post after huge exams!
i thought it said Toast 6 DVD chapters - does it work?
hahahaha
How do I get chapters and searching to work in a .TS stream
By jack616 in forum Video ConversionReplies: 10Last Post: 22nd Apr 2014, 08:57 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 18:27 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Toast 9
By lawnman in forum MacReplies: 1Last Post: 11th Mar 2008, 23:45
