Does any body know where to buy a big quantity of dvd-r 4x?
It will be in a quantity of 2000 or more, on going base.
Thanks.
TQ
Here's a deal for .88 per dvd 4X. for 1000.00, you might could see if they have a better deal for 2000.
http://www.shop4tech.com/user.htm?go=view_item&id=1437&cata=1&s_cata=88 -
BestBuy, 20 100 packs=2000. Roughly 200 per 100 pieces, though.
Just your're not gonna get a price break there. Ralph's 'Puters, next door also.
If you are looking to get real bulk pricing, look at the sites above.
And make sure the disk you pick is compatible before you commit to a couple thou, I don't care what the price per is. If they won't burn, they're worthless at 3 cents each.
And they'll probably be 20 100 packs, or 40 50 packs, and we have pipple here who have trouble with the last 10 or 20 of a 50 pack, so, what do you do? Check each spindle or pack to make sure they are all the same and all burnable?
You may have to go to the mfg to make sure you are getting what you want.
Cheers,
George -
meritline sells them in 1000 packs http://meritline.com/ritek-ridata-g04-4x-dvd-r-blank-media-disc-matte-1.html
about 85cents each .. you have to call for orders over 500-1000 to get daily pricing ...
ive had no problems buying from them ... though some others have ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
www.rima.com
you get price breaks when buying 2-4 and 5+ 100 packs. -
I may have found the best deal for reliable dvd+r that burn at 8x
Amazon have hte 100 printable Memorex dvd+r spindle for $84.99 free shipping and no tax for me.
That work out to be $0.85 / each, which is better than Ritek G04 at any of those other store.
Now, I am just cross my finger that Amazon carry those Memorex that made by Ricoh RICOHJPNR01, and not those crappy CMC MAG.F01 stuff.
If not, I going to shoot myself on the foot, jk.
TQ
problem with video frame quantity
By solteimartia in forum Newbie / General discussionsReplies: 14Last Post: 29th Mar 2011, 06:25 -
I'm still on the first road I have a large quantity of DVD
By krrish in forum Newbie / General discussionsReplies: 12Last Post: 10th Sep 2008, 08:15 -
I have a chance to buy a misubishi hs-hd 2000
By 2boot in forum RestorationReplies: 7Last Post: 27th Feb 2008, 20:43 -
Conversion Quality and Quantity
By faizy999 in forum Video ConversionReplies: 4Last Post: 23rd Jan 2008, 03:11 -
Wal-Mart offering (limited quantity) HD-DVD players for $100 tomorrow
By ViRaL1 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Nov 2007, 07:14
