Hi everyone!
I'm considering getting a polarizer for my handycam and thinking about getting the linear type so that I could adjust the effect. I know that circular polarizers are widely used for video applications.
Can I use a linear polarizer? What are the limitations?
Ken
linear polarizers will usually screw with the auto-focus ability of your camera. At least that's what it does with SLR style still cameras, not 100% sure on video cameras though, also screws with the light metering if it is happening TTL.
tito,
Thanks for your reply, however, I don't think that's entirely true. A lot of still camera AF lenses sport a rotating front element when it focuses, so a CP must be used. If the lens front is static while focusing then a LP can be used.
I'm just wondering, since most camcorder lens fronts are static, why is it that the CP is used most often and not a LP.
Ken -
shows that i'm still stuck in SLR mode from my previous job.
Actually the more correct reasoning behind using a circular as apposed to a linear polarizer is that the automatic metering system of your camcorder uses a polarizing beam splitter to judge the amount of light in a given scene, if you were to use a linear polarizer with this it would run the potential of causing a "blackout" where the light entering the camera and the beam splitter don't sync up.
Basically, give the linear a shot.. if it doesn't work then take it back and say u got the wrong one.. nobody should give you crap for exchanging for a more expensive filter.
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 18:00 -
Need some filters or something
By salatoimikud in forum Video ConversionReplies: 1Last Post: 28th Nov 2011, 13:33 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32 -
Looking for a ND filter as well as polarizer...
By B-Twien Bytes in forum Newbie / General discussionsReplies: 21Last Post: 26th Jul 2007, 08:12 -
virtualdub filters
By demonwarrior in forum EditingReplies: 5Last Post: 9th Jun 2007, 05:27
