I've had SVCD2DVD for a while now and have made a bunch of working SVCD DVDs. But seemingly out of the blue SVCD2DVD has stopped working. Now everytime it gets to the multipexing stage it just hangs there and never does anything. When I use Mplex the cpu meter disapears when it gets to the multipexing stage and when I use MplexWin32 the cpu meter stayes at 100% but the program stops working. I've tried all of the different combinations of options in the options screen. I've even tried re-installing the program and that didnt help. Now I've wasted my second registration key and SVCD2DVD still doesnt work. Below is the log file that SVCD2DVD gives me when I have MplexWin32 selected. Thanks for any help.
Starting SVCD2DVD: v1.51.2.0
Begin time: 2:14:28 AM
******** Ripping SVCD images to get mpegs (VcdXRip)
Analysing File: C:\CD Temp\American Idol\willykasts_NEW_a.mpg
C:\dvd-easy2svcd\svcd2dvd\vcdxminfo.exe: *** shared version mismatch detected - 0x18A2003F/0x18A2005A.
You have multiple copies of cygwin1.dll on your system.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version. The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.
Error getting mpeg details. (probably due to AC-3 audio)
System.IO.FileNotFoundException: Could not find file "C:\CD Temp\American Idol\willykasts_NEW_a_info.xml".
File name: "C:\CD Temp\American Idol\willykasts_NEW_a_info.xml"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
at System.Xml.XmlTextReader.CreateScanner()
at System.Xml.XmlTextReader.Init()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2b c216f3ce925842 a01d771a37e7320b)
-->Processing 1 mpeg files.
############### New MPEG File ###############
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file C:\CD Temp\American Idol\willykasts_NEW_a_DVD.mpv...
File C:\CD Temp\American Idol\willykasts_NEW_a.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 29535
System headers = 1
Padding Stream packets = 451, total bytes = 505985
MPEG Audio stream 0 packets = 2348, total bytes = 5382897
Video stream 0 packets = 27186, total bytes = 61696236
Saving stream 0xC0 into file C:\CD Temp\American Idol\willykasts_NEW_a-0.mp2...
Summary:
MPEG Packs = 29535
System headers = 1
(Total size: 65MB, Duration: 00:00:04, Rate(MB/Min): 825.08)
******** Resampling audio from 44.1 KHz to 48 KHz
MPEG Audio Decoder 0.15.0 (beta) - Copyright (C) 2000-2003 Robert Leslie et al.
8586 frames decoded (0:03:44.2), +0.7 dB peak amplitude, 98 clipped samples
Shibatch sampling rate converter version 1.29
frequency : 44100 -> 48000
attenuation : 0dB
bits per sample : 16 -> 16
nchannels : 2
length : 39564288 bytes, 224.287 secs
dither type : none
clipping detected : 0.133628dB
(Total size: 5MB, Duration: 00:00:37, Rate(MB/Min): 7.99)
******** Multipexing elementry streams
Encoding Time 8secs.
System.Threading.ThreadAbortException: Thread was being aborted.
at Microsoft.Win32.NativeMethods.WaitForSingleObject( HandleRef handle, Int32 timeout)
at System.Diagnostics.Process.WaitForExit(Int32 milliseconds)
at System.Diagnostics.Process.WaitForExit()
at ProcRunner.c5b4b7804027a156.160a0bf4de8f6bd0(Strin g d168ac2ed64c4662, String a6a477a49a1a2599, String 450f47a9028f884b, a0efedb9fec1e88f 8b49c96cd0348808, Boolean 74effd3a0f44569e)
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
Results 1 to 10 of 10
You have a cygwin version confilict.
Have you install any software which uses this: cygwin1.dll?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I have no idea. What kind of programs use cygwin1.dll? I have installed Sony Acid 4.0 and Sound Forge 7.0 and Fruity Loops studio 4. They are all sound programs, I don't know if they would use cygwin1.dll but I have installed all of them since the last time I tried useing SVCD2DVD. How would I go about fixing a problem like this?
Well first search your PC for cygwin1.dll and let me know the results.
I searched my whole computer for cygwin1.dll and I got three results. The first result was in C:\dvd-easy2svcd\svcd2dvd which is where I installed SVCD2DVD. The second one was in C:\cable shit\nopdocsis\nopdsis.zip and the second one is in C:\IRC\Download\nopdsis.zip. These last two files are inside of zip files. Before I first posted anything in this forum I tried doing a search for cygwin1.dll and found 4 more files then the 3 I just listed. I tried renaming them to cygwin1_old.dll but SVCD2DVD still did not work. The other four files that are currently renamed to cygwin1_old.dll are in
C:\cable shit\docsis
C:\IRC\Download\Data
C:\Invision2\Download\root tools\files
The weird thing is that I have had everything in the C:\cable shit folder before I even installed SVCD2DVD and it worked fine before. I dont know why its not working now. I hope this helps. -
ok can you deduce the versions and put the latest in the SVCD2DVD folder?
ok this is a suggestion:
can you download & do a mininal install of cygwin from www.cygwin.com? This should restore any registry settings & get the latest version of the dll which svcd2dvd will then use.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
It worked! I installed the new version of cygwin and SVCD2DVD is working just as great as it did before. Thanks a lot for all your help. Now my only problem is that before I posted anything in this forum I tried re-installing SVCD2DVD thinking it would help. I didnt relize I used my second and last license while I was re-installing it. I know I am going to upgrade my computer in a month or two. I was wondering if you could reset my license to one so I can install this great program on a faster computer. Thanks again for all your help.
Excellent!
Drop me an email & I'll reset your countSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
help for svcd2dvd
By dougal69 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2011, 18:05 -
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 27th Sep 2009, 13:41 -
SVCD2DVD and i7
By ttyke32 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th Mar 2009, 15:01 -
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Feb 2009, 14:58 -
svcd2dvd
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th Sep 2007, 12:34
