Hi
I'm trying to add a short audio clip to a motion menu using dvd lab trial. i created the simple video clip using animationshop - that appears to work fine. The audio i'm using is a 7ish second wav file 48KHz which dvdlab accepts and mutiplexes just fine. i can play the resultant menu perfectly using power dvd on the PC, the problem occurs on my settop, there is no audio on the menu and the dvd is rendered impossible to navigate and play. If i re-demux the vob using dvdlab, the m2v file is good but the audio file has a '?' in the status column and is not useable
what am i doing wrong please?
i have tried saving the wav as ac3 using cooleditpro when muxed the audio is not playable even on power dvd
sorry if this has come up before, i have searched, this is a massive site!!
thanks in advance for any suggestions, keep up the good work.
always open to new ideas
Try using FFMPEGGUI - works for me
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die."
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Menu editing after adding audio track
By Instant Martian in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2011, 11:23 -
TMPGENc Authoring Works 4 - motion menu no audio
By mobie29 in forum Authoring (Blu-ray)Replies: 3Last Post: 16th Jul 2010, 16:32 -
Adding audio to a MENU page
By efiste2 in forum Authoring (DVD)Replies: 8Last Post: 7th Feb 2008, 10:18 -
Removing and Adding New Audio to Mpeg Video for DVDStyler Menu
By dennis albright in forum EditingReplies: 0Last Post: 25th May 2007, 07:36
