Right don't know if it's me or the software but maestro always says this programme has encountered errors and will close when i try to compile a dvd??? All i've done is make a simple menu with ten boxes with a graphic on them to link to ten movies. I add ten movies to maestro and the one menu. then i stretched the left mouse over each picture to create buttons 1-10. Then i targeted all the buttons to the relevant movies 1 to movie 1 etc. Then i went to connections and changed all the targets to menu 1 because i want all the movies to return to menu1 when they finish playing. Then i auto assigned the buttons, pressed compile and then i get the error and it closes the programme. All i want is a simple menu that links to ten movies. I want the menu to be the first play. i don't want the movies to resume to the next. I want each one to play once and then return to the menu. Sounds easy?? I'm having a nightmare. Can anyone help or suggest software that will do this easier and more stable cheers or can anyone help me with maestro , cheers and thanks in advance
I would like to echo the same as I have the same problem.
Sam Ontario -
first off, what are your computer specs. secondly, sorry to ask this, but are you using a "cracked" version of mastro.
and lastly, what version of maestro do you have.
fifer55
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 21:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 02:59
