I am sure that this has been covered before. But, I was just wondering if converting avi to mov using Divx Doctor, would give problems with the audio? I played the avi file in VLC and the audio seemed to be fine, but, after converting it to mov, it started to get off around 19 minutes. Should toast be able to handle an avi to convert it to a DVD?
Assemble your crew, I'll meet you outside.
1. yes toast should
2. if not MPEG2WORKS will give you a .mpeg file which you can author as DVD
odd that the sync is out using divx doctor though...
give it a whril and see what happens.... -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
