I have all of the individual pieces of software for this program to run, however, I am using a new version of CCE, and when the program executes CCE, it just sits there as if no keystrokes/commands were passed to it. ANYONE know how to fix this, maybe if someone has a copy of CCE 2.5 i can use.
THX in advance.
DVD2SVCD requires CCE 2.50 (maybe v2.25 work too, but v2.62 does not)
OK,
so I know the version of CCE I am using is not going to work..Does anyone have the "trial" version of 2.5 that I can snag?
thanks a bunch -
Furble, dvd2svcd is a "one in all tool" ,it works with cce2.5 as encoder, so you'll get the quality of cce, no more no less.
if youre talking about cce , tell me is it possible to work with audio streams in cce ?
i mean with flask + avisynth + cce
because the cce only does the video
i have to use tmpeg or some other program to encode my wav/ac3 to mp2/mpa -
It is possible unless you use v2.50 and have a Athlon CPU.
Anyway the downsampled audio isn't so good. I suggest to use tooLAME for audio. -
We are maintaining an "official" Q&A for DVD2SVCD here for info on the latest DVD2SVCD:
Edit: DVD2SVCD got its own forum. I apologize for taking so long to fix this link. DDogg
pub28.ezboard.com/fdoom9smpegforumfrm34
DDogg
Doom9 Volunteer from Hell
<font size=-1>[ This Message was edited by: DDogg on 2001-07-31 15:07:28 ]</font>
<font size=-1>[ This Message was edited by: DDogg on 2001-07-31 15:07:56 ]</font>
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
