Hello im kinda new here.... i have some question.
I found out that only way if i wanted to join an xvid file without getting sync error is by spliting the wav and video and join them with tmpeg encoder. Is that correct ?
Ok here's my problem when i open my xvid file using virtuadub to extract wav i got error when i click on save as wave.
Full processing mode->save as wave.
Error initializing audio stream decompression
The request convertion is not possible.
Check to make sure you got the rite codec.
i even get this error when i use audio convertion method.
so i checked my xvid file with vdub file info
Video Lenght 17.44
Audio stream compression unknown tag (0055)
but the files plays good on divx playet/wmp
why i cant extract it ?
Results 1 to 12 of 12
Your audio is mp3 (tag 0055) and you haven't got a relevant mp3 codec.
The clue was in the VirtualDub message! -
I have checked the codec it seems like i have it all
Is there somewhere where i can download the codec for me to reinstall ? -
Audio Format:
Code: 0x0055
Vendor: ISO/MPEG
The following codecs all claim to be capable of processing this format:
--> {Fraunhofer IIS MPEG Layer-3 Codec (advanced)}
--> {LAME MP3 Codec v0.9.0 - 3.93 (stable)}
--> {MPEG Layer-3 Decoder}
DirectShow was also able to find a codec to render it - the sound for this media clip should work fine.
See the DirectShow Render details for more info. -
Im kinda messed up alredy
Do you have MSN messenger ?
teegee420 ?
I'll explain everything to you.
PM me your messenger address -
Install windows media player 9....reboot....try again. This should work, especially if you are not using XP.
Backing up Audio CD without compression.
By Bonie81 in forum AudioReplies: 2Last Post: 18th Nov 2010, 11:22 -
YT audio compression
By -Sandro- in forum Video Streaming DownloadingReplies: 0Last Post: 26th Oct 2010, 07:25 -
Audio Compression
By Nitro89 in forum ComputerReplies: 8Last Post: 2nd Oct 2008, 09:00 -
Out of sync Audio; Video Compression?
By Thortok2000 in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2007, 11:16 -
Audio compression with VirtualDUb!
By kehn in forum AudioReplies: 5Last Post: 27th Jul 2007, 00:10
