Hi
i would like to know if there is a good codec package out there that you woulkd recommand that i could download and install it on a fesh installed windows xp machine that would include DivX XVid Mpeg2 etc etc If possible without any spyware. I am looking for the more stable and complete set of codec so i can install all these file in one step.
Thanx a lot
Results 1 to 15 of 15
No, no, no. Don't. Take the trouble and install the codecs you really need, as you need them. Pretty soon you'll have a system that cand deal with 99.9% of every avi/mpeg you can throw at it, while not carrying around lots of redundant/conflicting codecs.
/Mats -
I think most people will agree that codec packs are not a good idea. The possiblility that they'll create conflicts on your system is just too great. You're much better off using something like G-spot to determine which codecs you need when you're not able to watch a particular movie and installing them individualy. However if you are lazy and don't want to bother with this and you want to take your chances, I'd recommend the K-lite codec pack.
Sorry have to agree,
Install as and when you need them, and do not install any you do not need.
I have seen a number of threads where the problems people have been having have been corrected by removing a unused codec or two.
Don't take the risk, spend that little extra time and download when you need them.
As teegee420 put, use G-Spot to determine any new one you need when you cant read a file.
Zworg2 -
Ok well i didnt know that it cold cause me trouble to install a package
so i will installed each of them manually
I would like to know if i download DivX version 5 codec
does this codec will let me read a DivX 3 movie ?
What other codec should i install beside
DivX, Xvid and MPG-2 ? -
ffdshow is a nice one to have around as default... DirectVobSub too.
/Mats -
What do you mean by that ?I don't use it for playback of any type of file
This package seem to have codec for DIVX 3-4-5 and XVID
But i can't read MPG-2 SVCD file. What do you suggest to install to be able to read those file ? -
I meant that I don't use FFDSHOW to decode any files when I'm playing them in my media player. As you mentioned, FFDSHOW can handle a number of different encoded files, but I use the individual codecs(Divx,XVID,etc.) instead of relying on FFDSHOW.
For mpeg-2 you can try this mpeg-2 codec, or install Power DVD. -
Ouch. K-lite if you insist on a pack. Avoid Nimo codec pack at all costs.
Pull! Bang! Darn!
Noob Encoding Package
By darkdream4 in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 15:44 -
Complete Authoring Package please?
By 1RealNewbie in forum Authoring (DVD)Replies: 3Last Post: 28th Sep 2009, 08:09 -
Best video editing package?
By donski in forum EditingReplies: 4Last Post: 3rd Jul 2009, 07:55 -
divx bundle package
By molinman in forum ComputerReplies: 1Last Post: 6th May 2008, 09:25 -
Picture Package Alternative
By cmcfalls in forum Capturing and VCRReplies: 0Last Post: 21st Oct 2007, 02:12
