Hello,
Wondering if anybody could tell me why this is happening.
I have an AVI file, captured from my digital camcorder via firewire.
AVI file is 9 mins 30 secs long.
I convert using tmpgenc, and the output mpg2 file is about 8 mins 50 secs long. I ran tmpgenc twice, and it gave identical outputs, both 8.50 long. It is not cutting the end off, so I can only guess is it is squeezing the whole thing.
Any comments?
Randy
Hello!
Maybe the framerate is different between the AVI-file and the MPEG-file, which could result in that the movie looks shorter.
/ Znooky -
Or maybe the player/tool you use to check the lenght isn't reading the time correctly. If you are making a DVD try authoring it anyway (the authoring application should fix the GOP timecode if there are any problems there), then play it with a software player from your HD and see how long it is.
Also check the source range filter in TMPGEnc. How long is the video there? -
Check that you are using the correct template in tmpgenc. Your options are PAL or NTSC. Make sure you choose the same standard as your camcorder uses.
Hi guys,
Thanks for the answers.
I had kind of given up on this post, did not think anyone was going to respond.
Craig,
I always pick NTSC, so that's not an issue.
Petar,
OK, I will try authoring and playing it.
BTW, what's the source range filter in tmpgenc? I will take a look tonight, when I get home, but I don't remember that.
Znooky,
I am pretty sure I always use 29.97 for the framerate. Will double check though.
Randy
Converted audio shorter than video
By rjc7394 in forum AudioReplies: 0Last Post: 15th Jun 2010, 00:14 -
Why is converted video shorter than original?
By mark86 in forum Video ConversionReplies: 1Last Post: 8th Sep 2009, 05:32 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 19:06 -
Problem converting HD (.mkv) to DVD (.mpg2) with TMPGEnc
By KPKMP33 in forum Video ConversionReplies: 4Last Post: 9th Nov 2007, 09:36 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
