  1. What's the best program out there to capture video through firewire at real time, to get best quality results? Then to output to DVD-R. My O.S. is Windows XP-Pro.
    <font size=-1>[ This Message was edited by: RimmeR on 2001-10-23 14:21:50 ]</font>
    Aug 2001
    San Diego
    #1. Shitty subject line. Any reason you couldn't type a normal one?
    #2. You don't CAPTURE anything via firewire. When you IMPORT video via a firewire card you are doing a simple file copy operation. With that said, Ulead makes a number of software titles that support DV import. http://www.ulead.com
  3. Its normally easiest to use the program that came with the firewire card. As it was already mentioned its just a transfer of data. However, if you use a pinnicle program you might want to export to avi and them use tpmg to convert to mpeg.
  4. Scenalyzer Live is the best. period.
    Try the demo, then buy it.
    Feb 2001
    Russia/Finland
    Sometimes I use DVIO.
  6. I have to agree with HackaShaq, I just started using Scenalyzer and it really is a smooth piece of s/w!
    Sep 2001
    Japan
    I'm using DVApp which comes with DirectX 8 as a DirectShow sample.It has a lot of options and runs smooth.No problem encountzer since using it.
  8. I capture DV video through my firewire port all the time. You can also call it importing, copying or transferring if you want.
    If you aren't sure how to capture DV video through your firewire port, check out the capturing guides on http://www.vcdhelp.com/capture.htm
    I'll have to try that scenealyzer out. Does it do multifile DV captures?
    Main concept will do multifile type 1 captures (so you can just capture your whole 60 minute tape at once), but you are limited to 4 Gb if you capture with type 2.
    Rimmer, I'm so jealous of your DVD-R. Let us know how it is working for you.
