Hi, i updated the firmware on my NEC 1300a dvd burner from 1.07 to 1.09. Now whenever windows is detecting the burner the system restarts. I desperately need some asistance. DOes anyone know what the problem is? can the update be reversed? Thanks.
System: athlon 2200+, 512ddr, geforce fx 5600xt, Windows xp sp1.
I appreciated any form of aid.
I have the NEC ND 1300a and I've never had to do it but my understanding is that you can install a previous firmware. I haven't checked but is 1.09 the latest?
You mean that every time you start your computer windows said that "a new thingie detected, please reboot"? I had that, rebooted once, it came up again, and I said "no" the second time.
So just hit no and then see if your burner works (it should), or update your firmware to 1.0A (the latest) -
I'm using the following hacked firmware. It allows you to change your bit settings. This is the first dual format drive to do that I beleive. (could be wrong)
http://www.herrie.org/modules.php?name=Downloads&d_op=viewdownload&cid=30#cat
LS
GE DV1 No Firmware Update What Is Up??
By DJboutit in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2011, 22:16 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 13:52 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 08:50 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46 -
Samsung SH-S183L firmware update problems
By Dr_Layne in forum DVD & Blu-ray WritersReplies: 1Last Post: 8th Feb 2008, 09:36
