I pulled the 6ch AC3 audio from the XViD with virtual dub in direct stream copy.
I converted it to 2ch wav via HeadAC3he, was downsampled to 44.1 etc.
I selected an NTSC film project (23.976 FPS with TMPGEnc).
Set a small source range.
Ran the sharpen edges filter.
And told it to do a straight CBR 2520 run through.
The result is an NTSC version that DOES play on my DVD player, but the image is jerky. The effect is subtle but annoying.
Is there any way to alleviate this subtle stuttering in the conversion process with TMPGenc?
Thanks.
Did it say "23.976 29.97 internal)
try runing pulldown on the file (hthe raw m2v not the program stream) -
I think you may have misunderstood me.
My XViD file is PAL.
I'm running it through TMPGEnc to produce an NTSC file. When I select an NTSC SVCD project, the final product (The new NTSC mpeg from my PAL AVI) stutters slightly.
I need to fix that stuttering, or know if I have to live with it. -
The right way to do a PAL to NTSC conversion is to change the frame rate from 25 to 24 with avisynth or virtualdub and adjust the audio length to match (I use besweet for that). If you just load the PAL clip in to tmpgenc and tell it to encode at 24fps NTSCFilm it will remove one out of 25 frames and you'll have that jerkiness you see.
Check out the list of guides on this topic:
https://www.videohelp.com/guides.php?howtoselect=4;41#4;41A man without a woman is like a statue without pigeons.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 11:55 -
PAL XVID to NTSC DVD?
By stanley_a in forum Video ConversionReplies: 4Last Post: 31st Dec 2008, 17:52 -
XVID/DIVX NTSC to PAL
By bilbonvidia in forum Video ConversionReplies: 14Last Post: 23rd Jan 2008, 23:13 -
Portable NTSC & PAL TV?
By Disco Makberto in forum Portable VideoReplies: 12Last Post: 14th Nov 2007, 22:31
