I want to get a dvd player this month..
It's between Sony Dvps300 or Panasonic RV31k?
hope u guys can give me some good advices..
Every review i read about are the same?!
lol, this will be a topic! If you want class & envy from you buddies, theres only one choice SONY
If they are all the same...maybe that should tell you something??..hmmm...however, it all depends on what you plan to use it for..I beleive both these models only play VCDs (well I know the panasonic does for sure)....and that Sony's are notorious for only accepting certain CDRs..they are usually good with RWs....as far as quality output, think they are closely the same...best bet, take a VCD/DVD/mp3 disk whatever you plan on using it for to the store...have them hook it up, and see which one you like.
<font size=-1>[ This Message was edited by: Kdiddy on 2001-10-23 14:20:13 ]</font>
Sony a33 or Panasonic GH1
By pjtn in forum Newbie / General discussionsReplies: 0Last Post: 18th Jun 2011, 06:47 -
Panasonic & Sony DVD/VHS recorders
By joecass in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Dec 2008, 06:56 -
Going HD with Sony - but with lots of Panasonic miniDV tapes to cap
By japniz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 13th Mar 2008, 22:14 -
Which do you prefer: Panasonic dvd-s2 or Sony ns67p?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Feb 2008, 14:31 -
Sony and Panasonic miniDV tapes do not mix
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 14th Jun 2007, 12:24
