  1. Banned
    Apr 2003
    Hungary, Europe
    Hello,
    I have a big problem: I have an mpeg-2 program, the sound and video is out of sync, there's a constant time between them (- same time between the audio and video at the start and at the end). How to fix it?
    I doesn't work with VirtualDub, as it is an Mpeg-2, nor VirtualDub Mod.
  2. The Womble Mpeg-VCR multiplexer allows you to offset the audio plus or minus. I've done as much as 30 seconds - it just takes a few tries to get it exact. You can use the tools section to demux your video and then mux it back with the offset. They have a thirty day trial without restrictions so you can try it first. Note that there is different problem if the audio is not offset by a constant amount across the whole video - the mpeg-vcr program will not fix that.
    -info
