I created a disc with a main menu but no submenus. The main menu shows up when the disc is loaded, but when a title is selected and playing, the "menu" button on my remote refuses to work (displays the "function unavailable" icon).
Is there a setting in TDA that enables/disables this? Or in the IFO file?
Thanks for any help!![]()
You didn't create a menu, so the button doesn't work. Try hitting the title button, since that's all you created.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I guess I should have explained that the "menu" button on my remote normally shows the main menu of the dvd. The "title" button allows me to choose a track number.
Just to clarify: the main menu allows selecting of all the tracks on the disc I created; I turned off the option for displaying chapter submenus. The problem is that once a track from the main menu is selected and playing, I can't get back to the main menu. I hope that makes sense.
My guess would be if you told TMPGEnc DVD Author to go to the track menu after the movie has played, there may be no instructions to link back to the main menu.
Just a thought... -
Before,burning always doublecheck,the pull down menu,to make sure of the return point..
i think u can specify the return point of each menu..
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
How To author an Episodic Disc w/Menu?
By Enginebuilder in forum Authoring (DVD)Replies: 10Last Post: 24th Dec 2007, 13:36 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 17:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 01:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 05:31
