I'm using tmge dvd authoring. The video comes out fine but there is no audio. What am I doing wrong.
cna you hear audio when playing back youe input files using media player classic ?
Always check helpfiles/instructions before leaping... -
No there is no sound produced from the input audio file I've tried wav. and mp2 files niether seem to work. any suggestions
Do you have audio in the source file ? And if so, how did you split it ?
Yes The source file has sound, and the audio file may have sound as well my audio system on my computer went down and I'm having trouble getting it back on. But anyway I used TMPeng to split it.
Probsbly best to get your system audio problems resolved first before trying to fix TDA no sound.
You have it set to produce BOTH elementary streams (ES), and not just the video, right?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
separating audio and re-authoring
By joecass in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2010, 10:37 -
Authoring with more than 8 tracks of Audio
By RefresherEllie in forum Authoring (DVD)Replies: 9Last Post: 2nd Sep 2010, 23:33 -
Audio problems with authoring
By moes in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2009, 15:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
