Hi!
I would like to connect my dxr3 card to my sony str db840 receiver, but I don't know how.
The card has a sp dif contact on the back and I know that I'm suposued to use that but wich cables should I use, and where should I connect the cable on the receiver??
Alvedon, maybe I can help I have the same receiver, which out put are you refering to on the card (my reciever is wired all over the house) nice box
I have been using my dxr3 (with latest sigma designs hollywood plus drivers via Remote Selector) to my Sony 5.1 receiver for a long time. You just connect a phono cable between the card's sp/dif connector to the receiver's 5.1 digital coaxial connector. The connectors on both ends are just phono type. Make sure you use a high quality phono cable. I then connect the dxr3 s-video to my s-video input on the receiver. It works perfectly.
Anya rules!
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
Is Dolby True audio and Uncompressed PCM worth a new receiver?
By yoda313 in forum AudioReplies: 7Last Post: 20th Apr 2008, 12:25 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54 -
Sony HT-DDW990 receiver - why display says "dolby digital 3/2.1"
By buzzinhornets in forum Off topicReplies: 6Last Post: 8th Aug 2007, 19:25
