I burned a 19+ min. clip onto CDRW (the same way as I normally do on DVD's I burn) that would play on my computer but not both of my standalone players. Can they be played on other players? I'm not talking about creating VCD's or SVCD's. I'm talking about copying the actual DVD files to the CDRW.
You'd be making an miniDVD, or cDVD (and yes, I know it's on a CD-RW, that's just what they are called). Most set-top players can not play these, but it will be playable on a computer.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
If your dvd player shows the minidvd as folders you can choose the vob file and play that way.
The only downside to that is a lot of players can't get the data off a CD fast enough because the density of the data prevents it being spun quickly enough.
If you've encoded your video at a fairly high rate it may stutter. loose lip sync etc. But if you keep the bitrate down, the results can still be quite impressive.
Question re "lossless" extraction of clips for later DVD authoring
By TURB0x in forum Authoring (DVD)Replies: 4Last Post: 9th Jun 2010, 05:08 -
Easiest way to "black out" a small section of video in an AVI file?
By johnny905 in forum EditingReplies: 7Last Post: 24th Mar 2010, 07:14 -
Making videos "for sure" playable in standalone player
By Meagain in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 17:39 -
"resume play" feature for dvds burned by dvd recorders (pioneer d
By barninga in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Nov 2007, 03:11 -
Burned DVD's "flicker"
By markannab in forum Authoring (DVD)Replies: 6Last Post: 27th Jun 2007, 03:45
