I have converted and resized a avi that was in 2.35:1 to a anamorphic mpeg2. But when i load the video in DVDLab u can read under"Ratio" 4:3 shouldn't it say 16:9 ?
Do I not need to be worried about this ?
It sure look like a 16:9 on my widescreen tv..?
Results 1 to 9 of 9
On your widescreen TV it should look OK, but if it's played on a 4:3 TV it will looked messed up. Did you set the correct (output) aspect ratio when you encoded to MPEG?
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Yes I did.
It was a 2.50:1 PAL source not 2.35:1.
Resize(704,412,1,0,638,256)
AddBorders(8,82,8,82)
Think this script worked well... -
Zefram Cochrane
2073 -
Shit!! default in tmpgenc 4:3 ?
I use AVI2DVD with a script.. so Maybe u are right.
I belived that program told tmpgenc that it should be 16:9...Because u just start avi2dvd and it loads up tmpgenc and u can't change any settings then...
Can i load my vob,ifo ,bup etc.... in Ifoedit and se if i got 16:9 ??
Thanks for your help. -
If you just did that automatically, then it should have set it correctly, but it might not have - I think 4:3 is the default when you load any video into TMPGEnc, but if you're using a program like AVI2DVD I think it can change the AR to the correct AR, but as I said, it might not have.
Yeah, you should be able to load the IFO file for the video (i.e. VTS_01_0.ifo) into IfoEdit, then in the lower window click on the line under "Title Set (Movie) Attributes", where it says "Video: MPEG 2". That line will tell you your aspect ratio, and if you wish to change it, double-click on that line, and a pop-up window will open where you can change that."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
How to change menu aspect ratio in DVD-Lab Pro ?
By V879 in forum Authoring (DVD)Replies: 2Last Post: 1st May 2011, 17:11 -
DVD Lab Pro
By Flying Doctor in forum Authoring (DVD)Replies: 6Last Post: 16th Jun 2008, 10:00 -
dvd-lab pro2
By postie1392 in forum DVD RippingReplies: 1Last Post: 15th Sep 2007, 06:32 -
Vob File has a aspect ratio of 704X480 in Dvd Lab Pro.
By mlong30 in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 00:24 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
