I am using vdub to capture
problem is I only have a limited amount of disk space around 20gig free or so
I am trying to record a 1 hour movie from VHS but end up with a file that is huge (18+ gig) I need alitle space left to encode in etc
I have tried huffy and PICvideo but still end up with 20 gig of file
my system can not handle real tiem divX or else i'd use it
Yes I know I need to badly upgrade to atleast a 2g system but right now I Cant afford it at this time but I know my problems will likey be soled when i do
but until then what can I do? anyone?
Try adjusting your picvideo's quality setting to around 12-14... the lower number used, the greater compression/smaller file size....you will lose a tad of viewing quality, but it may do you until the new rig is obtained.
Always check helpfiles/instructions before leaping... -
You shouldn't exceed 20gb with the PicVideo MJPEG codec even with a higher setting.
Before my Canopus ADVC-100 came along I was using setting 19 and I'm sure it didn't exceed 20gb/hr.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Can't convert very big file
By Julio33 in forum MacReplies: 3Last Post: 16th Dec 2010, 15:18 -
video file to big?
By just in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2008, 00:34 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
