need help, i got a HiVal DVD Burner.
my writing speed is 2X but it is suppose to be 4X.
dvdrw speed works fine.2.4X.
my dvdrs are BestMedia Platinum 4x and it only burns 2x.
i use nero 6 to burn my dvds.
any suggestions to increase my speed from 2X to 4X? thanks
dvdwriter
http://www.compusa.com/products/product_info.asp?&ref=cj&pfp=cj&product_code=307372
dvdr
https://www.videohelp.com/dvdmedia.php?selectmedia=626#comments
You need to determine what OEM model your HiVal burner is and check that manufacturer's site to see if you need a firmware update.
Many burners will not handle 4x media properly without the latest firmware.
Is possible to replace a different speed internal DVD burner?
By coody in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Dec 2010, 18:39 -
DVD writing speed
By DrAlanStatham in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 13:43 -
DVD Burner for writing Dual Layer
By StealthKing in forum DVD & Blu-ray WritersReplies: 9Last Post: 1st Feb 2008, 22:25 -
DVD writing speed problem
By dmckay2007 in forum Authoring (DVD)Replies: 3Last Post: 4th Dec 2007, 17:38 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 13:58
