I have been struggling to best configure my system for video capture. My current problem is that captures seem to be horizontally segmented across the screen. In a static shot its not really evident but the more the camera moves the more pronounced it is, with faster motion the screen seems to be made up of segments that blur together and objects get black saw tooth edges. My online research has left me confused. Is this an interlacing issue that won't show up on a TV screen? Is this a sign of an overloaded PCI bus so I need to reduce capture quality? Something else?
I have been capturing NTSC 29.970fps 720x480 YUV picvideo MJPEG quality 19. Thanks.
Yes, that would be interlacing, and no, you won't see it on your TV. If you plan on just watching it on your computer, you can deinterlace it, othewise, keep it interlaced.
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 15:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 10:02 -
horizontal lines in mpeg2
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2008, 17:05 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 19:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 12:06
