The easiest way to speed up the audio and keep it in sync is to get the wav file virualdub extracts and load into goldwave and stretch audio using 104.271% for ntsc to pal.
Results 61 to 68 of 68
Originally Posted by FulciLives
The root problem I have is the following:
Even if I convert the audio to wav without fps conversion, it won't sync properly with the video converted to 23.976fps.
Opening the video with VirtualDUB, gives a duration of 34 minutes at 29.976 fps and 62182 frames.
Obviously, the duration is incorrect as it is a 44 min episode.
However, the 62182 frames is a correct frame count for 43 minutes episode. So, converting the frame rate of the video to 23.976 and combining with the 23.976 fps audio as converted by Besweet without any fps conversion should give proper playback at 23.976fps. It doesn't.
The best approximation is to give audio a 1200msec delay and convert framerate to 24.93fps. This gives good sync for audio at the beginning and the end of the video, but in the middle (about 25 minutes) off-sync is about 1 second.
I am guessing that the reason is something to do with IVTC but even trying this gives worse results.
I have tried this with two separate DVD. Alias Season 3 and Star Trek TNG both in NTSC format.
Any guesses?The more I learn, the more I come to realize how little it is I know. -
Sounds like theres a point where the audio goes out of sync more than once so you have to look for that spot.
For any standards conversion you could try Dynapel's Motion Perfect software,but it only accepts AVI.The motion is extremely smooth.I use it quite often.
Well check this out guys and its perfect and very easy to convert pal to ntsc Click onto the following link and you wil be a pro in minutes.
http://www.angelfire.com/crazy3/mxc/Pal2NTSC.html -
Originally Posted by crownroyal
That is unacceptable.
The easiest method that is about as close-to-perfect as you can get is using DGPulldown.
Also this thread was more about NTSC to PAL than the other way around.
Exactly. And it is also for those that use very rare that type of convertions
Well thxs guys, just came across it and thought it could be at some help.
Just a Thanks pal to ntsc guide.
By Fat Tony in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 13:03 -
SatStorm's advices for the new Video Enthusiast
By SatStorm in forum User guidesReplies: 65Last Post: 1st Mar 2009, 12:08 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
