How the heck am I supposed to use the HD-BURN function of my DVD writer?
I feel like a complete newb.. the documentation that came with the writer makes no mention of it, and the software (Nero 5) that came with the drive makes no mention of it in it's help files either.
So, how exactly do I HD-BURN (burn 1.4gigs of data to my 700mb CDR)? with Nero 5?
Did you do a forum search ? This topic has come up a few times recently.
HD burn depends on your authoring software, drive compatibility and the use of specially certified media. If one of these isn't right, it's a no-go.
Don't forget you will likely be only able to read the disc back on the recorder - so don't expect great compatibility and to lose your recordings if that recorder of yours ever packs up and you can't replace it with a comparitive model... -
Originally Posted by maartena
@Logik,
What DVD writer do you have?
Have you updated the firmware? www.rpc1.org
Have you updated Nero? www.nero.com/en/631933457317970.html -
I have an optorite dd0201.
I have the latest firmware (2.5), and Nero5 like I said.. -
the best film ever made (some say) was "The searchers" plot outline
JW had just bought a dd201 and needed info
The electronic components of the power part adopted a lot of Rubycons.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
