i have an avi that is 640 x 352. the aspect ratio is 1.82:1 which is kind of odd. I normally set output to 16:9 and set input to 16:9 display, full screen, in tmpgenc.
what do you think is the best input/output settings for this AR?
should i correct the AR before using tmpgenc?
If it's 1.82:1, you could either trim it down to 1.77:1 (16x9), or you cuuld letterbox it into a 1.77:1 frame, by adding boarders, then encode as 16x9, or you could just letterbox it into a 4:3........
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
Some VOB's not displaying the correct aspect ratio
By Browncoat in forum Media Center PC / MediaCentersReplies: 26Last Post: 20th Mar 2009, 03:57 -
Correct aspect ratio
By dfisher052 in forum DVB / IPTVReplies: 8Last Post: 26th Oct 2008, 00:34 -
How to correct the aspect ratio (I see it in 4:3 but it should be 16:9)?
By Anonymous74 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2008, 08:10 -
how to correct the aspect ratio of AVI
By edong in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2008, 19:04
