  1. i have a web cam on my pc i started recording using win movie maker
    then i left for 5 days left it running came home and now i want to skim through the video
    problem is i cant seek or fast forword and it would take to long (5 days)
    to watch this video. can anyone help. should i convert it to another type of file formatt? if yes what type and what program would i use
    if anyone can help thnx in advance. id did a search and didnt find any how to 's or tutes .
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    This is a longshot but you might be able make the file seekable by using ASFTools. How big is it, anyway? I'm not sure converting to another format is a good idea considering that your file is in the neighborhood of 5 days long. Christ, I'm getting pissed off for you just thinking about how long that would take, especially with your CPU! Maybe splitting the thing up into smaller chunks would make it seekable. I've had pretty good luck splitting ASF's with this movie splitter.
  3. Originally Posted by teegee420
    Five days of video to encode on a 700mhz pc
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  4. the file is 2.65 gig so i thnk it might have stopped somewhere along the lines
    thnx for the help guys
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Try using the splitter I recommended and split into 250mb chunks. Hopefully they'll all be seekable.
  6. i tried that splitter tried 250 mb chunks it kinda just sat there for a whileafter about 2 hours there was still no progress and the prog wont convert to any other file format any last resorts?
  7. If you have the hard drive space you can remux to Matroska.
    ASF content will seek just like an AVI when repackaged as Matroska.
  8. Member yhe2x's Avatar
    Dec 2003
    NJ, United States
    2.65 gigs...Deng!......that's one hell of a video......
