Hi
i just converted a avi into a mpg2 with TEMPGEnc using the video and the audio in separate files. When i try to open the file with windows media player it plays correctly. if i try to open it with classic media player it take a least 2 minutes to open it. If i try to open the file in Ulead Video Studio it take more than 5 minutes to open it. My guest is that there is probably a problem with the file some missing frame, file corrupted or something else.
My querstion is how can verify that and is possible how can i correct the file so it can be opened in a normal time 1-5 seconds ... instead of 2-5 minutes
Thank you very much for your help
Results 1 to 1 of 1
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 02:32 -
DVD Lab Pro 2.20 ERROR. Check inside!
By nick_gr in forum Authoring (DVD)Replies: 3Last Post: 28th Jul 2010, 09:54 -
How do I check if a file is HD
By no_alone in forum Newbie / General discussionsReplies: 5Last Post: 26th Jun 2010, 10:35 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 22:35 -
Blank Check Command Error In Nero????
By steveuk200 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2007, 03:31
