As with many other people I have sync problems when capturing from video tape with my Hauppauge PVR 250. Files play fine on the computer > usually author ok with DMF2 but are always out of sync with TMPGENC DVD Author, DVD-Lab & other progs.
Has anyone here tried using the DataVideo TBC 1000 time base corrector with the PVR 250??
I hate dropping $300 to solve a problem I already thought I solved when I bought my PVR 250.
_________________
"Understanding Is A Three Edged Sword"
Ranger One the only time you need time base corrector if recoder files always out sycn from a VCR with just a few tape but record from reg AIR TV are fine with or without any editing.
It possable you have a few bad frames or audio pocket loss which encoder maybe dropping so when you try edit them it out of sycn.
Some eles some ely ver with heatsink are know run HOT that can cuase sycn problem check the chip be sure it not runing HOT if it is add a fan close by to help it run cooler.
Try new MPEG editor called VideoReDo http://www.drdsystems.com/VideoReDo/
Datavideo TBC-1000 Power Supply (PSU)
By Gibson's Squares in forum RestorationReplies: 3Last Post: 1st May 2012, 19:22 -
Datavideo TBC-1000 problem (artifact)
By VCRcomp in forum RestorationReplies: 3Last Post: 6th Nov 2011, 21:43 -
datavideo tbc 1000 is my unit dying?
By mazinz in forum RestorationReplies: 9Last Post: 2nd May 2011, 22:01 -
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 12:02 -
DataVideo TBC-1000 and the Broadcast Flag
By robjv1 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 11:23
