I found something weird with a couple of my original movie DVDs:
Movie#1 - Close Encounters of the 3rd Kind (Collector's Edition)
I turn on English subtitle, fastforward (8x), subtitle disappears, play normal speed again, subtitle does not come back for at least 10-20 seconds (yes, actors are speaking). Even if I switch subtitle off and back on, it still takes 10-20 seconds for subtitle to appear again.
Movie#2 - Office Space
I turn on English subtitle, fastforward (8x), subtitle disappears, play normal speed again, subtitle comes back within 1-2 seconds.
Both DVS's are original and tested on 3 different players (Apex, JVC and RCA) plus WinDVD on my PC. All behaved as I described above, consistently.
Now, to my subject, I use DVD Maestro 2.9 to author my home DV video with date+time code in the subtitle. After I burn to DVD-r with NERO, it behaves just like Movie#1 above. Obviously, I would like it to behave like Movie#2. Perhaps there are certain settings in DVD Maestro to fix this? Perhaps Scenarist would solve it (I don't have it to test)? Any other ideas?
sounds like the length of the subtitles is whats going on, since you fast forward, it obviously skips the subs for that particular scene/s. i have had similar problems with subtitles, and found that the duration of the particualr sub is more than likely the issue, and or the chapter point(highly unlikely, but it has crossed my mind).
anyway, as far as checking in maestro, try playing with the length of the subs, see what happens. sorry i couldnt help more
Ok. I'll do more testing.
I started with my subtitle as date+time code which updates every second. The problem is that whenever the subtitle changes, the whole subtitle goes off and comes back on. Doing this every second creates a flashing effect which is very annoying. So, I decided to update the subtitle every minute and just drop the seconds in my time code. This was better but created the second problem as described in my top post.
I wish there was a way to eliminate the time gap between 2 consecutive subtitles. I tried to overlap consecutive subtitles and it seemed to help but it still flashes to a smaller degree which my eyes picked up and distracted me from the video. Besides, I believe overlapping subtitle is non-standard (even Maestro complained but went ahead and compiled anyways) and may or may not work properly on all DVD players. Any other advice?
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
how to make a DVD subtitle as a default playing subtitle
By yozloy in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2008, 11:51
