  1. Does anyone know where I can get FM tuner PCI card for my PC. I alraedy have a ATI AIW 7500 that i'm extremly happy with so I'm only interested in purely FM tuner PCI card.
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Umm, why would you want to do this? Can't you just get an FM radio and connect it to your sound card? It's not like there's going to be much noticeable sound quality loss.
  3. I use a USB FM tuner that works fine for me. It is the D-link USB PC Radio DSB-R100. It hooks up to your USB port and has an RCA mini 1/8inch stereo plug you need to plug into your line-in port on your sound card. I picked it up for about 10 bucks in a clearance sale at Office Max about a year ago. D-link no longer supports this unit but if you can find one it should suit your needs.
    No, I'm from Iowa. I only work in outer space.
    Jul 2003
    london uk
    the winfast xp2000 deluxe is a capture card and a fm tuner card in one. i got mine on ebay in the uk for £40. i know you got a capture card already but i have never heard of a fm tuner card on its own. the winfast is actually very good.
