i want to take video i've recorded on my standalone, rip it to pc, and make some new menus. they don't have to be fancy. can someone recommend a good program for this?
Rip in IFO mode in DVD Decrypter.
Edit in Womble MPEG VCR if needed.
Author in any old non-encoding authoring program.
I use DVDit! PE and TMPGENC DVD Author oftenWant my help? Ask here! (not via PM!)
Originally Posted by harmsway1976
Originally Posted by lordsmurfDom Robinson
Editor, http://DVDfever.co.uk -
just save your video ts folder from your recorded dvdonto your hard drive
and then use tmpeg dvd author and click add dvd video. you will still have your ac 3 dolby sound, but you will not be able to hear it with dvd author while editing. very simple and easy to use. i do it all the time -
Originally Posted by dvdfeverWant my help? Ask here! (not via PM!)
I took the DVD and used File Mode as above, but did use stream processing in DVD Decrypter to get a .m2v file (in 768x576) and .vob sound file.
Using the Wizard in TMPGEnc Plus, I converted the video file alone down to 720x576 (which takes about twice as long as the file actually plays for), even though Windows Media Player sees the resultant mpg file as a 768x576; and I renamed the audio file from .vob to .mpg and used the De-multiplex option to convert it to an .ac3 file.
Then I put the two together in TMPGEnc Plus in the 'simple multiplex' option to produce one final .mpg file.
Using that in Adobe Encore DVD is fine and I can create menus etc, but it picks the menu image for me, and I'd like to select my own but can't see how I do this. When I recorded the disc in my Philips DVDR75 in the first place it let me set ndividual menu images which I did carefully, but now there's no actual option I can see either to set one, or use the same as already set in the standalone recorder.
I'd appreciate any further help on this. TIA,Dom Robinson
changing region code on DVD/VHs recorder
By graceee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 1st Jun 2010, 08:07 -
standalone 16:9 recorder
By dnyboy in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th May 2009, 13:37 -
My standalone DVD Recorder is a
By Baldrick in forum PollsReplies: 31Last Post: 12th Nov 2008, 15:21 -
Home Videos DVD - Changing Menus
By FBI Agent in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2007, 21:16 -
DVD Recorder Standalone
By ebob in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 11:40
