Whats the best program to use when creating a mpg (2) format from an mpg (1)?
Why are the best things things in life cost the most money?
Who stole the rest of my Signature, Own up, it was you, yeah you, thats it I am gonna come over there and .......... -
Cheers for that, I have been using MainConcepts MPEG encoder and sometimes having a few problems, I have also tried TMPGEnc but that doesn't do such a good job.
I have ran Virtual Dub and I have imported my mpeg file but I don't know the settings or how to save it into an mpeg (2) file as all the saves are for .avi
Is there a really usefull guide on this product?
JLRWhy are the best things things in life cost the most money?
Unless I'm completely off-planet at the moment (this is always a possibility) VirtualDub only saves to .avi files.
You'd need to frameserve to an encoder from VirtualDub or load the .avi in the encoder directly...
TMPGEnc should be able to do a fairly good conversion internally. Remember, though, it's somewhat GIGO in this case, as you're taking a 'limited' stream and simply applying it's 'lesser' standard to a format with more 'robust' standards. -
you are not completely off-planet (at least in your answer above
) -- v-dub can not make a mpeg2 file ...
also -- the question should be raised, is there a need to convert mpeg1 to mpeg2 ? often not .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Just needed the reality check, having been discussing the practical use of nuclear weapons most of the day.
JLR,
Is your destination DVD? If so, you can author DVDs with MPEG-1 video...
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 16:04 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
