Files - VCDQual gave it good rating - It is a screener rip
-1-MOVIE TITLE.SVCD-FLiX-1of2_MD.mpg
-2-MOVIE TITLE.SVCD-FLiX-2of2_MD.mpg
Files Specs. Video & Audio attributes
-D1- File : 751 MB (1001 MB), duration 0:50:52, type MPG, 1 audio stream(s), quality 88 %
Video : 920 MB, 2530 Kbps, 29.970 fps, res. 480*480 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 81 MB, 224 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
-D2- File : 751 MB (1.1 GB), duration 0:52:56, type MPG, 1 audio stream(s), quality 88 %
Video : 957 MB, 2530 Kbps, 29.970 fps, res. 480*480 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 84 MB, 224 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
Problem:
I have used TMPG..plus, TMP..Author, UleadDVD, and a host of others to get this thing into proper DVD!!! The problem I am having is not a visual problem, all is ok with that... the problem is the audio synch.! Which I have de-mux them and put back together using EVERYTHING and using all kinds of settings and dvdrhelp guides! I burned it as SVCD and the audio was fine. All codecs are fine. When watching the original & burned SVCD.. synch is on time. When watching DVD files produced by TMPGPlus & Author and burned DVD synch is off... alot! Like 5-10 secs!
What I am Thinking:
During the encode/convert... the bitrate of the files plus that f'n 480x480 transformation into DVD standard 720x480 is f'n up the audio sync!
Queston:
First is it possible to have a 480x480 DVD? I have no knowledge of 'frameserving' but is this a case of it (then i need to learn about frameserving)? Or is it just something else that I am missing? If u have burned a working DVD standard Monster from this particular screener what did u use and/or steps? If u use TMPG.. do u use the pre-loaded templates that come with it for burning diff. formats (svcd,DVD NTSC, etc.)?
As for 480x480 DVD´s (I supose NTSC)
from this very site
NTSC DVD-Video standard
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
As for the audio is it off by the same ammount through the entire movie or does it get gradually more (or less) off synch? -
(audio) It is constantly off sync from the very beginning... not gradually. Any clues?
I can´t tell you what´s causing it to go off but the best thing you can do is to measure as exactly as possible how much is it off and then add silence in the begining or remove accordingly.
You might not get it right at first but it´s not that hard.
Good luck. -
UPDATE
First let me say thanks to all the help you guys have given me! And also for just for taking the time to even read my post.
What i did was use DVD2AVI to convert it to .d2v and (audio) .mpa first.. and then used TMPGEncPLUS to do the rest. And all went good. -
Begone I say! No WAREZ !!. I see thy soul has not been cleaned and thee continue to sprout forth thy blasephemy! May disaster strike thee of biblacal proportions! Begone evil warez buccaneer!! Swat, Swat!
MTS to MP4 conversion without re-encoding
By steven2583 in forum Video ConversionReplies: 21Last Post: 4th Nov 2015, 10:56 -
Encoding Problem
By mdnightsky in forum ffmpegX general discussionReplies: 3Last Post: 29th Jun 2011, 14:35 -
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 17:04 -
Problem with Encoding
By benchlol in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2009, 20:04 -
Encoding problem
By silverpurple in forum ffmpegX general discussionReplies: 1Last Post: 21st May 2008, 14:31
