Results 1 to 10 of 10
  1. Member bballnut's Avatar
    Mar 2003
    I need to no what I did wrong when I used DVD Shrink to backup a dvd of mine. I want to leave the closed captioning in the copy but missed it somewhere in the copy. I used DVD Shrink, Autoshrink, and Nero to backup the dvd. Where did I go wrong?
    A little guidance for a newbie, please.
  2. you didn't use 3.1.6 perhaps?
  3. Some versions took out the captions, get the newest version, its got better features anyway.
  4. Member bballnut's Avatar
    Mar 2003
    I used version 3.1.3
    I will try the newer version. Do you have a link to the newer version?
    thanks for your replies.
  5. Hmmm.... DVD Shrink (hint...link) keeps subpicture intact since at least v3.1.4, when I started using it. I always have to un-select it for each Title.
  6. Member bballnut's Avatar
    Mar 2003
    A newb question.
    i downloaded version 3.1.5
    do i need to uninstall version 3.1.3 first and install 3.1.5 or
    just install the newer version?
  7. Latest release is 3.1.6 and a newver beta version 3.1.7b4. I install over every release and just change the exe from the beta download.
  8. Member bballnut's Avatar
    Mar 2003
    I went to dvdshrink.org and the version there is 3.1.3.
    the links there were older versions.
    I also went to dvdshrink.info page and they have suspended downloads from their site. the link here for dvdshrink takes you to dvdshrink.org
    does any body have a link to a site with the newest (3.1.6) version for download?
    Oct 2003
    Virginia
    i just checked, the dvdshrink.org site does have the latest versions(3.1.6 and 3.1.7b4). Go to www.dvdshrink.org then click on the american flag, then click where.
    It's on that page. Enjoy!
  10. @bballnut, are you using any proxy/cache, you may need to clear your cache, there is 3.1.6 release (4 links) and 3.1.7 beta 3, beta 4 and beta 5.
    http://www.dvdshrink.org/where.html
    This are the 3 lines at top:
    Where is DVD Shrink?
    DVD Shrink is freeware. Use the links below to download your own copy:
    · Current stable version: 3.1.6 - 02/23/2004
    If you don't see that, then there is a problem with your browser.
